I have tested DVD Region-Free as someone mentioned , but still I can't play the dvds i have. I think this software doesn't work. I also tried to update the firmware of my dvd-rom, but I still get the same result. My dvd-rom is LG DRD 8160B . I got the updated firmware from the site www.firmware.fr.st , I followed all the instructions, but nothing. Can anyone please help me???
Results 1 to 14 of 14
Did u change your Software DVD Player's Region setting.
Your software(dvd player) region setting cannot be set to 0, however a program called "DVD Genie" will reset the number of times u can change the region.
I have WINDVD and i must change the region setting if I want to play region 2 dvds.
This takes one change from my allotment. However DVD Genie will reset my alotment to 5. -
No, my dvd-rom is a RPC-2 and using DVD Genie won't work as I already tried to use.
The software my friend.
WinDVD, PowerDVD, they have to be changed to, DVD Genie will change them.
DVD Genie still says your drive is RPC-2 even after you flashed it? -
Dear all,
We have uploaded the new version of DVD Region-Free 1.0 RC3 and fix the region mis-match problems coursed by "DVD Region Killer" software. If you have installed the software before, please uninstall the "DVD Region Killer" and try the new version at http://www.dvdidle.com/download/DVDRegionFree10.exe
If you also have the same problems with DVD Region-Free 1.0 RC3 after you uninstall "DVD Region Killer", please let us know at support@dvdidle.com
Best Regards,
Fengtao -
There is a reminder in the instructions to obtain a region free DVD software in www.firmware.fr.st.
PowerDVD and WinDVD just won't work. They are region setting programs.
Sound as though the change as not successful. Did you do a test in the computer's drive, driveinfo11.exe. You can download the "driveinfo11.exe" from firmware.
The test will tell you whether the drive is RPC-2 or RPC-1. Your drive is supposed to change to RPC-1, "This drive has no region protection" If it has changed successfully, then it is the program causing you the problem.
I haven't installed the freeware software yet as I can play a DVD movie in one computer as region 1 and the other as region 4. There is no hurry for it. -
I Have an LG DRD8080B and use a prog named RPCMAN it resets the
drive to 0 again so you have another 5 times to change region you can
also use it to disable the region until you reboot its made by LG and I
have read some where it will also work on your drive if you can't find
it on the net post me and I will email it to you?
hope this helps
spyda -
I did the test using the driveinfo program, but after I flashed my dvd-rom, it still says my dvd-rom has region protection. And don't say that I used the wrong firmware, because my drive still works fine with my dvds.
I just tried to use RPCMAN, it's true that it works for my dvd-rom, but when I open this program, I can't choose my drive, there's nothing in the pull down box, that's very strange. Does anyone know why it happens to my drive???
sorry for this, the RPCMAN worked, it's because I put the win32api.dll in the same folder as RPCMAN.
But now what I really want to know is, why my dvd-rom is still RPC-2 if I flashed it with the right firmware???
My drive is LG DRD 8160B -
either it didn't flash, the firmware is faulty or it isn't reporting right.
Dear all,
DVD Region-Free 1.05 Release Updated!
What's new:
1. Distorted video problem when a title doesn't have menu fixed.
2. PowerDVD XP freeze problem after playback starts a few seconds fixed.
3. Asynchronous IO mode supported.
4. Notify user to uninstall other region-free software such as "DVD Region Killer".
5. Several small bugs fixed.
You can get it at http://www.dvdidle.com/download/DVDRegionFree10.exe
Any questions, please let us know at support@dvdidle.com
Best Regards,
FengtaoDVDFab - Copy DVD and Blu-ray Disc to DVDR, BD-R, MKV and iPad/iPhone/iPod.
http://www.dvdfab.com
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Problem with Region Free DVD Player
By The Monkees in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Apr 2010, 08:57 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
