I have AVI files that I would like to frameserve using Virtual Dub, to convert into MPG files using TMPEG Encoder. However, I am unsure of what to do regarding the file's color depth settings.
Virtual Dub's help file (under "Contents>Advanced Topics>Frameserver>Setting up the Frameserver") states that video output depth does not function in Frameserver mode, and that "Frames are always sent in 24-bit color. Note that the decompression color depth is used."
When I open up the original AVI file in Virtual Dub, and look under "File>File Information," the AVI Information window lists "Uncompressed RGB16" under "Decompressor."
I do not want to change the quality of the video that I send through the frameserver. What option should I select for decompression color depth ("Video>Color Depth"): 16-bit (HiColor/32K), or 24-bit (TrueColor/16M)? I would appreciate any help.
Results 1 to 1 of 1
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
Color Depth
By gingka in forum Video ConversionReplies: 4Last Post: 20th Aug 2009, 21:53 -
Change Color Depth 24bits to 12bits
By PBoy in forum Video ConversionReplies: 6Last Post: 6th Jul 2009, 13:05 -
Xvid 8 bit color depth resoultion problem
By afcoff in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 23:50
