when i am converting The Fast and The Furious using TMPGEnc, i got the whole movie so i have to use the clip source option to split it. However, the audio line does not move. I tried another DIVX (AVI) movie and it still didn't work. Then i used a regular avi movie and it the audio line did show that there was audio. i need to know what to do.
1,First make sure you have the audio codec's, install the Nimo codec pack. Now try...
If that still gives a problem then you need to save out the audio in Vdub then use that with TMPGEnc
You can also change the DirectShow to a higher priority in TMPGEnc
2
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
3
Vdub save audio uncompressed at 44.1Khz
Audio > full processing mode
Audio Compression > PCM (Default)
Audio > Conversion > 44.1Khz
SAVE WAV
4
AC3
Vdub save audio
Audio >Direct stream copy
SAVE WAV
Rename .wav to .AC3 then use "headac3he" to convert to WAV
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 10:40 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
Mpga Audio in Vegas 9.0 doesn't work
By NarutoS212 in forum EditingReplies: 3Last Post: 24th Dec 2009, 19:47 -
Audio doesn't work on HDMI. Something wrong with the TV?
By Xavier in forum Software PlayingReplies: 1Last Post: 14th Oct 2009, 00:07 -
DivX created by ffmpegX doesn't work on player?
By ambrosechapel in forum ffmpegX general discussionReplies: 7Last Post: 17th Oct 2008, 07:13
