Hey, i'm looking for a video capture card, for internet use. I'm basically looking to make some Divx and RM quality. maybe Vcd if i can handle it. I would buy a All in wonder radeon if i had the cash, but i just need something to settle for now.
my system specs are
850 mhz athlon amd
256 mb ram
30 gig hard drive
cable modem
I'm not looking to spend more then $100
I have a Sharp Hi- 8 camera..
And it's going to be for breakdancing footage so it's gonna have alot of action, the movies come fine to vhs, but, i need them for internet use.
CAN anybody help please.
- Spidey
oh boy here he goes again..
You can try an ATI TV Wonder mine is a little buggy, make sure u have an ATI vid card
i have a brand new card i can't use (bought two, no win2k support) so check your private messages if you're interested
I use a DC10+ for my VHS to AVI capturing. Uses MJPEG so the actual captured AVI is not all that big. Nice and easy software added too.
Do some filtering using VirtualDub for better output.
Later use tools like TMPGEnc to convert the AVI to VCD.
Result is very nice.
I saw it at some stores for about $99
It bought it not so long ago for double that amount.
Need help buying a Capture card for xbox match recording
By Raw_Habitz in forum Capturing and VCRReplies: 23Last Post: 9th Apr 2011, 18:08 -
help buying video card hdmi????
By bammthis in forum ComputerReplies: 1Last Post: 14th Mar 2010, 04:58 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14 -
Buying a new TV Out card.
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2007, 09:41 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
