I've been fiddeling around with my WinTV PCI/ BT878 for quite a while, and I know it's NOT possible with this card to capture FULL PAL RESOLUTION (768*576), but it IS POSSIBLE with letterboxed movies without any combing effects! The capture chip is the issue here - when the data rate gets too high, it seems to lose frames, which leads to putting the wrong half-images together (also called interlacing artefacts).
NOW - let's say I'd invest 250,- € in the WinTV PVR ... but then this card is using an 'advanced' version of the BT878 (BT878 fusion)... Does anybody have this card - or anything like it - and what's the quality like?
Well, VHS is about to die, so there should be some digital replacement to my the VCR that's really working, even on the PC (you won't notice the interlace problem if you view the image only via TV, I've read) - no dropped frames due to the capture chip. What about external digital recorders? I don't know anyone who has one, and it's hard to tell what they're really worth without serious testing (the Nickles 'geeks' (www.nickles.de) will tell that 384*284 pixels is enough - haha!).
I'd like to know your opinion.
Results 1 to 1 of 1
big headache with capture card and new nxp chip
By mammo1789 in forum Capturing and VCRReplies: 5Last Post: 26th Jan 2012, 13:11 -
Capture Card With No Delay Input Capable of 720p+ @ 60fps?
By NeoCyrus in forum Capturing and VCRReplies: 34Last Post: 4th Feb 2011, 00:32 -
Modern consensus on best sub-$250 lossless AVI-capable analog capture card?
By Mini-Me in forum Capturing and VCRReplies: 31Last Post: 9th Jul 2010, 06:18 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 17:49 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 19:29
