    Aug 2002
    Hello all,
    I am burning a vcd movie that is 2hrs long. Right now I am using nero and it's encoding. Should i have cut the movie into two parts first or can i just put in another cd when this first one is full? I am using 80min cd.
    If i have to cut the movie into 2 parts, can i stop this process now and still use this cd or is it ruined?
    Please help.
  2. it may fry on you anywhy because I believe that nero, while encoding, determines if the encoded file will fit on one CD.
    The answer to your question is that you should have probably cut it into two pieces, encoded (using something other than nero - recommend TMPGENC - in the tool section to the left), and then burned to vcd/svcd using nero.
    Your message about will it ruin the cd. While it is encoding, it is not burning.
