  1. had 2 divx avi movie files rencoded with tmpgenc and sound with headache joined all together everything ok
    sound in sync on both files
    tryed joining with tmpgenc mpeg tools now out of sync 2nd half of movie
    wat do i do
    thanks
    cheers theskid
  2. You might want to try joining the two DivX AVI files first in VirtualDub (or other programme) and then encode to a single MPG in TMPGEnc.
    May 2002
    Rainy City, England
    You might try the *multiplex* option with each mpg using TMPG's mpeg tools before joining (making sure you choose the type as mpeg-2, and save with a different name). Check the sync. Then after joining, do a multiplex on the combined file, using a different name to save with.
