I tried to cut a avi file with VDub but i am getting this message.
"VDub has detected an improper VBR audio encoding in the source avi file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce upto 13421 ms of skew from the video steam. If this unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate 113.3 +-8.6kbps)"
I let it rewrite with standard CBR values and encoded it to mpeg but there is no audio sync and the skew of several seconds between the audio and video is very annoying.
So how do I "decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate 113.3 +-8.6kbps)" ?
Can someone explain how to do it in a simple way to a newbie ? (I have nero,vdub,tmpgenc)
thanks
Use Virtualdub to extract the audio using this :
http://www.vcdhelp.com/virtualdubaudio.htm
then encode with TMPGE using WAV as Audio Source"Today is only yesterdays tomorrow"
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
vdub and audio
By jimbb in forum AudioReplies: 1Last Post: 9th Apr 2008, 10:17 -
sudden vdub sync problems when converting hd sources
By uk_dan2k in forum Newbie / General discussionsReplies: 10Last Post: 8th Feb 2008, 16:37 -
Sync Problem when loading into Vdub MPEG2
By ebayer077 in forum Video ConversionReplies: 0Last Post: 2nd Aug 2007, 13:55
