what the hell is going on? can someone help me out?
Sure... no problem.
The "OUT OF HARD DISK SPACE" error means that you have too much stuff on your hard disk to be able to add what you are trying to add. SOLUTION: Get a larger HD or remove some stuff off your HD.
The "DATA RATE TOO HIGH" error means that the combined data rate is too high. For DVD, the MAXIMUM DATA RATE is 10.08Mbps. This includes the VIDEO, which cannot exceed 9.8Mbps, your AUDIO tracks, which can be as high as 1.5Mbps and your SUBTITLES which, fortunately, are only around 10kbps each. Add up your stream DRs and see if they exceed the specifications.
Some authoring programs do not like it when your VIDEO BR is above 9.5Mbps.
Hope that I answered your question... If not, try to be more specific in your questions.
Does recoding a 7gb mkv file require a lot of hard disk space?
By dave in or in forum Video ConversionReplies: 3Last Post: 21st Aug 2011, 17:01 -
Exporting a little movie file that won't consume my entire hard disk space
By Danny Pro in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 23:50 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
