    Aug 2002
    Michigan
    I have many cds with svcds on them which I burned with Nero. Using nero changes the format i guess. I was thinking the format would be changed to .dat but instead it is still .mpg. That's my problem, I've tried just copying the mpg and trying to edit it and use different programs trying to load the mpg but all of them have error messages "not supported", etc. I was wondering what a good program is to do what i'm trying to do and the instructions i need to know to use the program(s). Thanks in advance.
    Maverlck32
    Feb 2001
    Berlin, Germany
    Do you mean "Extracting MPEG from SVcd?"
    Which program did you use to edit?
    Did you read some forum topics today?
    Aug 2002
    Michigan
    i burned an svcd and i just want to be able to take that movie off the cd and use tmpgenc to edit it.
  4. Use CDRwin to extract bin cue then use Vcdgear to extract MPEG2 from bin & Cue.
    I'm old, but still going strong!
  5. i use VCD Gear to extract MPEG from SVCD/VCD
