When encoding a video from a rip DVD, which resolution would produce a better images? A resolution of 352x480 or 480x352 given all the encoding parameter are the sames for both resolutions.
The more "lines" the more detail that will come thru. For this reason, you should always use the HIGHEST resolution possible (720x480/576).
Higher Vertical Resolution...
I've been experimenting lately with the following numbers for the viewable area of an XVCD MPEG-1 stream:
4:3 Aspect Ratio - 352 x 480 NTSC or 352 x 576 PAL (ALT: 320 x 480)
16:9 Aspect Ratio - 352 x 400 (ALT: 320 x 352)
2.35:1 Aspect Ratio - 352 x 304 (ALT: 320 x 272)
In each case the full encoded frame is 352 x 480 pixels NTSC (or 352 x 576 pixels PAL). The viewing area is centered and letterboxed on a black background. In this way you can have an XVCD with twice the vertical resolution of a 352 x 240 (or 352 x 288) pixel encode. This is fine for viewing on PC (using Sasami2K) or Sega Dreamcast (with Dreammovie VCD player). It might not be so compliant on standalone VCD or DVD players though.
Unta Glebin Gloutin Globin,
Akai Rounin, The Cyber Sage
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 09:17 -
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 21:46 -
Edit wedding video from vertical appearance to horizontal
By technofox01 in forum EditingReplies: 13Last Post: 19th Nov 2007, 12:47 -
Mobile video Horizontal - Vertical
By wayneyg in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 11:07 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 14:53
