Hello to you all!
My first visit here and I´m glad I found it.
So my question is: Should it take me up to 3-4 hours to encode a 50 min film with TMPG?
Seems a bit boring to wait for such time.
I have a 450Mhz 128kram computer, Can that be the reason?
Ok but I love this site and the stuff you can find here.
So...
Results 1 to 20 of 20
Best Regards // Roger
Hehe is it?
Oh soo then I dont have too worry about somethings wrong, except my Computer sucks and my English is awful?
Thanks anyway....Best Regards // Roger -
Bye the way.
You guys hoo have some 1.x Mhz computers, how long time does it take for you for an 50 min movie with TMPG?
Soo I know if it worth it to spend some cash for a new one.Best Regards // Roger -
Are you encoding to Mpeg1 or Mpeg2? What res are you encoding to? Are bitrate method are you encoding to (VBR, CBR, 2-Pass VBR?) They all take a different amount of time. On my Athlon 1800 it takes me around 10 hours to do a 2 hour 720x480 stream using 2-Pass VBR. If I remember correctly it only takes like 1 hour 06 mins to do a 44 minute stream at 352x480 using Mpeg2 VBR (not 2-pass.)
It still will take you a long time on a faster machine. An entire movie (100 minutes) takes me about 4 hours to encode to mpeg1.
That long ? on a 1.4 is that Intel ?Originally Posted by ZimZ
100 min about 90 min -
I love this stuff, I have a 400 Mhz, when rendering a 30 minute SVCD I start it night when I go to bed so it will be done by morning, usually 8 hours.
sadly, i too have a 450mhz p3, so it takes me about 3 or 4 hours to convert to svcd's with TMPGEnc, but i usually do what agent0008 does and leave my computer on all night
My PC takes about 4 hrs to encode an AVI to VCD specification mepg1.....
It's an Athlon 1.4 @ 1533mhz with 512 meg ram, SVCD can take 2-3 times longer! -
Guest
You think thats slow..........On my K62-500 SVCD ,2 hour movie..........try 75 hours!!! but the results are stunning!!!!!
3dcandy that time seems long for a vcd conversion, I have a 1.4 athlon with 512 ram and it usually takes me about 2hrs to convert from a DivX?
i have a 1.8 ghz p4 comp with 512 ram and ton of hd space, and it still takes sooo long for svcd, about 18 hours for a normal 90min movie. But the vcd takes about 4 hours, of course i only encode with the slowest highest quality setting. Is there any way i can make my vcd(mpeg) to svcd(mpeg 2) proccess faster, any priority environmental settings i need to put up? Cause damn, 18 hours for a svcd highest quality, with a very high bitrate, i made the file size to fit two 700mb cd-r so that 1.4gigs of space and movie encoded(the movie i am doing now is happy gilmore lol).
The time to encode is based on what you are encoding from and if you are filtering. If I'm just re-encoding a 320x340 divx file to vcd, I can do a 45min show in about an hour on my 1.33GHz Athlon. However, my usual frameserves from Virtualdub to TMPGenc can take 2-3 when the source is in Huffyuv at 720x480. I HAVE, on occasion, taken 24+ hours when I used some TMPGenc filters. The same conversion took less than half of that when the filtering was done by Virtualdub and frameserved to TMPGenc.
Anything at or above 2GHZ on Intel cpu's is basically encoding at real time, 50min in equals 50min out unless filter/frameserving are involved which slightly increases the encoding time. Built a p4 2.53ghz box and it encodes in real time when using CBR at Very High Quality, 2x playing time if 2pass VBR MPEG-2. Mpeg-1 is .85x real time CBR and 1.5x playing time with 2pass VBR.
Depending on what mobo/Athlon XP combo [greater than 1650mhz] you're running, encoding is at or below real time. Got one [only a BIG A$$ HSF combo for cooling] 1734mhz[+2100] oc'd at 1839mhz that encodes in less than real time with filtering either through Virtual Dub or DVD2AVI when it comes to 2pass VBR MPEG-2 CVD streams encoding is close if not near real-time; CBR MPEG-2 CVD is about .90x playing time with filters/frameserving. Haven't encoded Mpeg-1 on this box but I assume it is right up there with my Intel 2.53ghz box or maybe less considering how recent my p4 box is.
Dusted off the ol' p2 400mhz workhorse and encoding a 43min [Digital Cable source] AVI in Virtual Dub with 2d cleaner & Contrast filter frameserved to TMPGEnc and encoding 2pass VBR MPEG-1 [yes 1] took a whopping 8 hours. I do not miss the leave encoding at night routine anymore. A DVDRIP frameserved with DVD2AVI to TMPGEnc with no filters was around 8 hours.
Thorn,
Found the same observation as you, a good temporal noise cleaner used in Vdub will get the job done A LOT faster and cleaner than if someone was to use the noise reduction filter in TMPGEnc, which takes up way too much time on the high quality setting. -
Not quite right, I have a 1.6 and 50 min would take lessOriginally Posted by deadpac
I always use a high quality source, and always have all settings on max quality - plus I'm usually either online and/or doing something!!!
If I'm not multi-tasking the pc I'm asleep, so I don't know/check how long it takes.... -
For all you overnighters,:
frameserving from flask or xmpeg isn't the most popular
method around these parts, but it comes with a very handy
"shut down the computer when done" box that you can check. -
50min VCD on standard VCD settings on an AthlonXP1800 usually takes me about 40minutes, on CCE it takes about 20 or less.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 02:11
