i have this avi file which is missing like 3mb
and it's not my fault - it's already truncated on the fserver
i guess, it's 3mb at the end, it should be less than a minute of
movie time...
can i convert it to svcd? players(wmp or windvd) woulnt open it.
and how do i do it?
would the usual procedure work just fine? vdub+tmpgenc?
Only one way to find out! See if it can load into Virtualdub first. If it will, try *scan video stream for errors* and re-save it, using *direct stream copy*. Chances are you won't be able to open it. If not, you may as well search for a utility called Divfix and try that.
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
"IsoMedia File is truncated" Any solutions?
By m93 in forum Video ConversionReplies: 3Last Post: 20th Sep 2009, 21:09 -
h264 - IsoMedia File is truncated
By HoraceX in forum Video ConversionReplies: 1Last Post: 22nd Nov 2008, 18:53 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39 -
DV => wmv, file truncated
By zoobie in forum Video ConversionReplies: 3Last Post: 12th Jul 2007, 18:50
