I used DVD2avi just as Danib666 suggested and there is a great difference in the quality of the sound now. The metallic sound has disappeared and I´m very pleased with the result
Results 31 to 39 of 39
I never downsample to 44.1 khz as my player can read a 48 khz stream just fine on my SVCD's..you may want to see if your player can handle non compliant SVCD's and just skip the downsampling step altogether.
Gotta love those cheapo apex players
it is possible that one of the many codecs you have installed is causing you this problem
i only have divx3 divx4 divx5 ogg and the mpeg2 codec from powerdvd installed -
yay! nille
glad someone has benifited from my advice
DanW - the main reason i downsample my audio is so that i can lend the finished svcd to my friends and family in fact the main reason i do most of my movies is for friends and family. since i probably only watch 1 in 10 of the ones i get! but if the only reason that you wanna get the movie is so that you can watch it then yes you are best off checking that your dvd player can handle non compliant vcd/svcd's -
Danib666,apparently the problem is only on my PC,when i play the SVCD/VCD on my standalone the audio is fine.So the DVD2AVI solution works,as i never use my pc to watch movies anyway.
nope using external audio encoders like toolame thru tmpegenc doesn't sort this problem, the only way i found was thru dvd2avi.
although there may be other external programs that do it, dvd2avi was the only one i got to work
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
Virtual Dub converted files poor quality.
By stark88 in forum Video ConversionReplies: 4Last Post: 8th May 2011, 23:39 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45
