I ripped a dvd(valentine) with CLADDVD XP and it worked fine it then done frameserving through DVD2AVI after that was done i had the 2 files to use in TMPGENC.
It converted to Vcd brilliantly(no errors or no warnings).
I then burnt it with NERO and it burnt perfect(again no errors or warnings)
but it wont play on my dvd player,
it wouldnt play at all and when i put it on my pc to see if i could watch it on that it showed nothin it was just a blank cd.
This is my first time ripping dvds and i followed the instructions from this site (how to fit a whole movie on one cd) and it still dont work.
My dvd Player does play vcds as it has played them b4.
I would really appreciate it if some1 could help.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
DVD Ripping help
By nsx-r in forum DVD RippingReplies: 3Last Post: 30th Apr 2009, 19:56 -
some1 with alot of xperience plz help,regarding avi to dvd?
By just in forum Newbie / General discussionsReplies: 3Last Post: 16th Oct 2008, 22:42 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11
