Hi there ,
I have been using DVD2SVCD since a couple of weeks with CCE 2.5 with no problems at all but now I found some problems in converting to SVCD some DVDs . (not with all)
It doesn't play well (scenes not fluid - it seems like a bitrate problem) while it is OK playing it on the PC .
Someone has an idea of what the problem could be ?
Alessandro
Hiya,
are you ripping DVD's with a different format than before?
eg: Ntsc Pal Forced Film Hybrid ??
One way to tell is by running DVD2AVI (it is in the DVD2SVCD folder)
and loading the ripped VOB's. By pressing F5 you can get a preview
of the film plus see what "kind" of film it is. -
Thanks . I've checked the video format and it was interlaced . So I just tried to specify "smart deinterlace" in DVD2SVCD and it worked fine then.
Alessandro
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
