I just upgraded to win2k today and now cce will not load the .avs files. Does anyone have this prob or know what could be causing it? thanks for your time.
Results 1 to 12 of 12
update...one of the errors i am getting is, " according to the registry the type of file specified does not have a handler to process it" does anone know what handler i need? again i just upgraded from winme and never had this type of problem before. if you have any suggestions pleaes let me know. thank you
You need to create a custom ECL. If your not sure about how to do this, either create an avi from VFAPI, load that into CCE, save ecl. In the saved ECL look for your file.avi, and change it to your file.avs.
You can do the same with a project file from TMPG. This of course assumes you used DVD2AVI.
Your using CCE 2.5 right? 2.62 can't use avs files.
<font size=-1>[ This Message was edited by: disturbed1 on 2001-08-10 00:29:20 ]</font> -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
disturbed1,
Could you please elaborate on this? It sounds very interesting to utilize the advantages of both TMPGEnc and CCE...
Thanks.
BeTa
Beta, yes i am using 2.5. If i use your method do i then need to resize also? I have resized the .ecl before but my encoded video does not turn out. If i were to use tmpgenc i know i can resize in there but then do i load the tmpgenc file in cce or do i convert the tmpgenc file to a avi file? thnaks for responding Beta.
What disturbed 1 means is,
Create a dvd2avi project file
select it as video source in TMPG
set source and output aspect ratios, if you like filters too
save the TMPG project (.tpr)
convert the TMPG project with VFAPI to *vfapi.avi
add it to the cce encoder list and encode.
So you resize and add filters in TMPG and the pure encode is done by CCE.
The other way, that disturbed1 mentioned is,
create a dvd2avi project file
then convert this .d2v to.vfapi.avi
create your avisynth script (to resize and add filters)
add the *vfapi.avi to the cce encoder list, set everything you want and save as whatever.ecl
Now open whatever.ecl with notepad. Change widht and height corresponding to your avisynth script. Change the file name from whatever_d2v-vfapi.avi to whatever.avs
Close whatever.ecl (yes,save changes)
Now start CCE, select file> open whatever.ecl, encode.
THANKS DISTURBED1 AND TRUMAN FOR EXPLAINING THIS...TRIED IT AND THE PROB IS GONE. THANKS AGAIN
C'mon guys,
Could you tell me how you convert the *tpr to *vfapi.avi?
My VFAPI does not recognise the file format. Is it something TMPGEnc version-specific feature? Does TMPGEnc have to be open with the project in the meantime?...
BeTa
check Doom9'z site for utility downloadz and more..
VFapi
http://www.doom9.org/Soft21/mpg/VFAPIConv-1.04-EN.zip
dont know what da latest version is/
zTr
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 05:12 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 28th Feb 2009, 23:34 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 13:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 17:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 11:21
