sorry, didnt know where else to turn, not really a vcd question, but how far is it safe to overburn? like say i want to take my pink floy CD's Dark side of the moon(about 42 mins) and Wish you were here(about 44 mins) and throw them on one 80 minute cd, would that work out alright?
If your burner is a Cyberdrive,LG or Lite-on yes it is safe.Most writers can
burn 89min.(using a 90/99min cd-r) but the disk may be unreadable by
your cd player(unless you use the before mentioned writers).
If you don't have those brands I mentioned then overburn at your own risk because you could damage your writer. -
there has never been a documented case of cd-rw damage due to overburning.. infact there are measures inplace to prevent it.. i have an hp 12x cd burner and it can burn 97minutes without a problem..
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57
