Hi everybody,
I´m new here, I´m impressed with these forums.
Ok, the problem I have is that I download the film "THE HOLE" on divx. When I try to conver it with TMPGEnc 2.57 appear a message that say that it is not supported. Trying with Panasonic mpeg1 encoder ver. 2.1 appears the typical message "Window ha ejecutado un operacion no valida.....". With Virtual dub 1.4 appear message : DIVX05 need.
How can I do to convert it to vcd.
Thanking you in advance
Salva
Download and install the appropriate divx codec, or try installing the nimo codec pack as it is probrably in there.
Craig -
Hi craigtucker,
Thanks for your quicky answer.
I have installed divx 5.02 and I can see THE HOLE with windows media player. I had nimo codec pack but I had to uninstall it because Panasonic mpeg1 encoder ver. 2.1 don´t work with it installed. I use Panasonic to conver the divxs that its sound don´t work with TMPGEnc 2.57.
I have to put the codec in some specific place or inform it to TMPGEnc 2.57???.
Any sugestion???
Salva
Using TMPGenc for DVD to DivX with consistency.
By meneedit in forum Video ConversionReplies: 8Last Post: 26th Jan 2012, 07:15 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 16:21 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
I have a problem with TMPGEnc 3.0 with DivX...
By blasedeviant in forum Video ConversionReplies: 2Last Post: 1st Feb 2008, 22:10 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
