I burn VCD's with Nero 5.5.9. My CD-r's are 24 speed but the maximum speed with which i can burn on my HP9110 is 8x. When i play my newly burned VCD's on my stand alone DVD player the beginning is always good but as we get later into the movie(disc) it seems to slow down and becomes jittery(the picture freezes for upto 1/2 a second and then goes on with the next frame. Imagine seeing a punch being thrown, picture freezes with the fist on the nose and the next thing you see is the guy lying on the floor. sound remains okay and goes on normaly!) Does this have anything to do with the burn speed in relation to the CD-r's ?? Or could there be another reason for this erratic behavior.
Thanks in advance
Eddy
Did you use TMPGEnc templates PAL or NTSC ? Your player may only play fully compliant VCD's. Also the quality of the CDR is important on some players, only you will be able to find out what is best for "your" DVD player. Same with burning speeds, only you can figure that out. I sometimes burn at 40X with no problems, but that means nothing to you.
1, Burn at 8X
2, Use Maxell or TDK
3, Load a VCD template in TMPGEnc
You need to experiment
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 21:43 -
DVD's not playing properly after being burned
By Digger777 in forum Video ConversionReplies: 5Last Post: 25th Sep 2008, 23:52 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 16:51 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 07:46
