here are the problems:
dvd cannot be accessed at all...
it wont play, drag to hd, of ripped using smartripper
according to smartripper...i need to unlock the dvd before ripping, but to do so, i need to actually play the movie...which i cannot
why is this? ...perhaps of a very strong protection??
another thing, my friend found a cnet article dated feb. 02 that said this:
"Technical plans aren't final yet. But essentially a watermark would insert instructions directly into the movies that would tell DVD players and recorders whether a movie could be copied. If it was copied illegally, the movie could not be played on hardware that included the watermark-recognition technology. These instructions would theoretically be carried with the movie even if it was copied using a program such as SmartRipper"
could this perhaps be the problem? if so....can YOU help me find a solution?
-i am dennis
				Results 1 to 14 of 14
	I have personal knowledge that A.I. can be ripped. Try to use dvdx. Havent used smart ripper, but I am very pleased with the VCD results of DVDx. Look in tools section to the left.
	same problem...i need to unlock the dvd by playing it, but that is impossible because i cannot play it
	I am going to have to ask a potential real stupid question here. do you have DVD rom on your computer that you are putting the DVD into to play/extract.
 Also, does this DVD play on your standalone DVD player?
	yes i have a dvd-rom that i am putting the dvd into...and yes i do have a standalone dvd player which actually plays the movie
	sorry, since you didnt fill out your technical/computer profile, I have to ask some questions like that. I am trying to think what it might be....region stuff on the DVD, but since it plays in your stand alone, which I assume you bought in the same country that your dvd rom was bought....nothing readily comes to mind. I have ripped A.I. with dvdx and it works great. I dont think I am going to be be able to help you.
	hi, please try dvdx agaian and could you copy and paste the error message and then post this?
 also, input settings for dvdx, under decss, please make sure that aspi is checked and key search is set to once.
	to macloud:
 my comp specs are:
 1.5 ghz p4
 256 sd pc133 ram
 60 gb hdd
 pioneer dvd-rom dvd-117R
 ...i doubt any of this would affect the ripping or playing process, but here u go anyway
	to stevemoley:
 tried DVDx again, and heres the error message:
 "auth.dll: Can't authorize drive
 Disk may be locked"
 ...thats exacted wat it says
	what software player(s) are you using to play DVD's? I am at a loss as to what the problem is. I am assuming that the DVD deosnt have scratches on it, your pc dvd player plays other dvd's.
 The watermark issue wouldnt affect that because you cannot even play the DVD.
 the only ideas that I would have is to play another DVD, pause it, take that one out and then put AI in there and try to play that one. The only other thing would be the copy of AI. Take it back to the store and get another one. It might just be the DVD itself????
	1) Does you DVD-ROM play any DVDs?
 2) What STUDIO put out the DVD?
 3) I really suspect that your DVD IS locked. Play another DVD to see if this unlocks the drive.
 4) The Watermark thing hasn't been implemented yet (though why they insist on spending money on something as easily defeated as that, I'll never know...).
 5) Does this DVD play in a set top player?
 6) What is your OS?
	thanx for the help everyone...but for some reason, WinDVD was the only player that actually played the movie
 i tried wmp, powerdvd, microdvd...i guess they all suck
 windvd solved my problem of not being able to play/rip dvds
 thanx people
  Windows Movie Maker 6 - Problems with playing timelineBy leegutcher in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2013, 14:16
  Ripping Blu-ray Movie "BULLITT" Audio ProblemsBy titot4u in forum Blu-ray RippingReplies: 1Last Post: 16th Nov 2009, 11:22
  Movie-Only Ripping - full main movie shows up as more than one titleBy ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13
  bluray ripping and playing questionBy kschewe in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2009, 00:45
  AutoGK - experiences and problems of ripping a larger movie collectionBy vchrizz in forum DVD RippingReplies: 2Last Post: 22nd Sep 2008, 18:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
