ok...quick question...Is there anything comparable to TMPGENC that will work on my 32meg 300mhz Cyrix to allow me to convert avi's to mpegs??? This seems to be a problem....
when I went to download it, it stated it required 64 megs ram and at least 500mhtz processor....I have neither...will it still work? a lot of these things I've tried to download states something similar....just wondered if it will hurt my comp...I want to burn to disc so I can watch on the tv...maybe it doesnt make a diff if you're doing that...I have no idea....I appreciate the help...
You can still download and try it.
It shouldn't hurt your PC in any way - TMPGenc is a pretty friendly program and doesn't go changing anything else or associate any file types to itself. You can even have multiple versions on the same machine without any conflicts.
The worst that could happen is that it will lock-up when you try running it and you'll have to re-boot. Just don't have any important unsaved files open before running it.
The only problem you will likely find is that it will take quite a long time to encode files on your processor. It is optimized for Intel processors so that along with your processor speed may make things even slower.
I say give it a try, either it won't work, or it will, but it shouldn't hurt your PC and it is easy to remove.
I don't know of any other encoders that would be any better on your computer. -
hey...thanx for the advice ...I went ahead and tried...it works fine...I cant get it go to disc for crap even though my burner already has the ability to burn mpeg to vcd...but it didnt work...dont know how to get the full picture on it either, but I'll figure it out eventually...thanx for the advice
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
