I finaly burned one, but the quality was really poor. It looked extreamly pixi. I took a 1 min test AVI, converted into Meg1, then burned in nero. I used a program called avi2vcd. I did download a program that everyone seems to recomend called TMPGE. What is the best way to get the best quality. I am looking for a VCR quality, no biggie. Its family film. Or, is a SVCD compatable as a VCD to a Sony DVP560D? I seem I cant find the Speces for it. If this is possible to play on my set, then can someone help me as far as 'How' I go about conversion.
But as far as the possiblity of improving the quality of a VCD, this is my main question and I would be satisfied with any answers.
Thanks Much
-Hyper
AVI2VCD is the worst program I have ever used.
I abosulty recomind you use TMPG. It is the most powerful freeware encoder. -
Are you saying that this could be my problem? Is the TMPG that much better?
Thanks!
-hyper
<font size=-1>[ This Message was edited by: HyperJoe on 2001-08-09 20:57:45 ]</font> -
Tmpgenc is the best that I have used, I use the 2-pass Vbr setting on NTSC and burn as svcd. This has produced the best results on my system. 400mhz pentium II. It takes a while, so be patient.
Did you test silver layer CD-R, because this is the brand tested by users as informed on "DVD Players" for your model (Sony DVP560D).
Best format to use to maintain video quality?
By Blackhawk1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Apr 2013, 01:17 -
Does rendering to same format hurt quality?
By R Man in forum Video ConversionReplies: 8Last Post: 22nd Nov 2011, 18:14 -
Which format to convert to for best quality?
By Crapozo in forum Video ConversionReplies: 5Last Post: 4th Feb 2011, 19:23 -
Best Format Quality For Blu-Ray
By betonz in forum Newbie / General discussionsReplies: 15Last Post: 6th Jul 2010, 22:45 -
Loss of quality with MPG2 format
By KayAt in forum Newbie / General discussionsReplies: 4Last Post: 23rd Mar 2009, 14:58
