im using Cinemacraft encoder, and when it finished encoding, it left me with an audio and video file. how would i join the two?
Use Virtualdub (for AVI) or TMPGEnc (for mpg).
In Virtualdub open your video and then your audio and make sure Video and Audio setting are set to Direct stream copy.
If you use TMPGEnc cancel the wizard (if it starts). Go to the File menu and select MPEG Tools... Use simple multiplex to join your video and audio together.
Good luck!dj matty b
Video Files, join video_ts and flash video
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 06:45 -
Audio Sync trouble with Join
By RedDwarph in forum ffmpegX general discussionReplies: 8Last Post: 12th Apr 2009, 08:24 -
Join tool issues with audio
By ComicFan2 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Dec 2008, 22:41 -
How do i join video and audio file together
By ultraman36 in forum EditingReplies: 1Last Post: 15th Jan 2008, 17:24 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
