I captured from VCR using Matrox Marvel G400-TV card into my win98SE system successfully. I can play the caputured avi file with mediaplayer.
When i used TMPGenc (v 2.57) to encode it to VCD, the TMPGenc monitor is not showing the full picture. It shows, what seems to be some video at the top left hand corner of the monitor, with 99% of the others in black, with some grid dots. It finishes the whole file and no errors reported.
When l played back the mpeg1 file, it shows exactly what the monitor was showing when it was encoding, some sort of "video" at the top left hand corner!
I suspect that the video captured by Matrox G400 may not "convert" the avi file properly to enable TMPGenc to recognise it somewhat!
I have another avi file from another source, not captured by the G400 card and have no problems with TMPGenc!
Thanks in advance
Are you using a compression codec? Which one is it, and what are your settings?
Have you tried Virtual Dub with compatibility capture? -
Thanks, l found out myself! The VFAPI plug-in for my system was too low a priority in the Environmental setting in TMPGenc. I jack it up and its now working. Thanks.
How to properly convert interlaced MPEG to AVI?
By lovyagin in forum Video ConversionReplies: 1Last Post: 12th Nov 2009, 05:34 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Avi files not running properly
By Skyline in forum Newbie / General discussionsReplies: 6Last Post: 25th Dec 2008, 09:22 -
Tmpgenc Xpress 4 stream reading error
By WinSpecToR in forum Video ConversionReplies: 8Last Post: 16th Oct 2008, 07:50 -
.AVI is not properly converting to .FL when using ffmpegX
By - Ø®£Z - in forum MacReplies: 9Last Post: 27th Jul 2007, 16:07
