  1. I have heard some say yea and some say no.... so whats da final conclusion?????? Does somethings play better if burn with nero and some with unlead (which i wanna try real soon) what is the best software to use burnin when it comes to u wanting to play dvds in your ps2 AND XBOX ????????
  2. AND THE ANSWER IS????????????
  3. I would say that if you want to play on your ps2 and xbox then the quality of the media is more important than what program is used to write to the disc. I've been having a difficult time trying to get my dvd movies to work on my ps2, but have been having decent results since I started using Datasafe Generation-3 media (not perfect but better than before).
    Also if your using nero to burn, try the DVD-Movie option along with ISO level 1, ISO9660 naming and no relaxations to the file system.
    Hope this helps.
    RealaT Bytes, but that's what life is.
  4. " Also if your using nero to burn, try the DVD-Movie option along with ISO level 1, ISO9660 naming and no relaxations to the file system. "
    can u explain that part to me..... also i tried verbatium and they work just fine in my ps2 but not xbox
