I'm trying to make a VCD with TMPGE and VCDeasy with a japanese video file for the source which, I believe, has been encoded in a PAL format. The trouble I'm having is that the subtitles are being chopped off the bottom of the screen and the image is too wide when I display it on a tv screen. If anyone has had any experience with this or knows the best way to remedy this problem, I would appreciate their help. Thanks.
Search the forum for "overscan". Probably you will find the answer.
Truman, what program can i use to add switchable subs to SVCD, i read i can add 4 subs to an svcd, but with what program?
WinsubMux can mux subs to SVCD and CVDOriginally Posted by ^GeX^ChRaN :-)
ChRaN, i already try it, i select the MPG file and the SUB, when i click in Multiplex appear that error: ´Ñ´ is not a valid integer value , im doing something wrong or what?
Did you read the readme file, you must manuly remove the first lines in the .sub file including[LIST] so only the "list" remains.
ChRaN :-) -
Multiplexing...
*** Incorrect packet[0xBA010000] header at 0x00000004 ***
* Unknown header 01 bb 00 09 *
* Skipped 2310 bytes of garbage *
Warning: No subtitle added
What about that ChRaN???, that appear, when i click in Multiplexing, i convert the subs to, .sub with his .BMP files using the Maestro SBT
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 16:41 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 22:30 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 11:16
