Is it possible to load an XML file created by VCDEasy back into the program for editing? Specifically, if after creating a BIN, viewing it in DAEMON Tools and deciding to tweak some of the chapter settings or fix errors, is there a way *not* to have to start from scratch?
I know you can load an XML into VCDEasy to create a BIN, but I don't have the expertise to open the XML in Wordpad and edit it from there.
Thanks,
Bruce
1. Don't close VCDEasy.
2. Learn to edit the XML manually (suggested!): http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 17:08 -
MKV XML chapter file creator
By perdigueiro in forum LinuxReplies: 3Last Post: 30th Jan 2012, 08:44 -
FCP not recognizing a XML file
By lcquintana in forum MacReplies: 0Last Post: 17th Oct 2008, 12:54 -
Button Navigation via DVDAuthorGUI xml editing
By awesomer in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2008, 04:26 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 16:25
