  1. any way i can stop it cause every single day it say that after i lose so space and should i maybe buy a new cdrom or dvdrom cause i saw one for 50.00 that plays cds will that help it not say low disk space cause the ones that are use up space are imesh and direct connect and all the stuff that have my movies on it so i like it so i dont want to get it destroyed. thanks
  2. If i understand you correctly you are getting a low disc space warning on your pc. This has nothing to do with cds drives, it means that you are almost out of space on your hard drive. You can either delete some stuff from your hard drive (make sure you empty the recycle bin) or buy a second hard drive.
    Craig
