i just installed the card and it works fine.
the program freezes sumwhat often but ill probably get different software for it anyway.
but the audio sounds fuzzy and not that great.
i have the loopback wire that came with it going from the tuner card into the MIC on the back of my computer.
i think that it looses quality by doing this
did i do this right or is there another way to make it sound better.
thanks for any help!
