  1. I have a divx of 10 things i hate about you but the sound is 3/4 seconds earlier then the movie.
    Is there a way to edit the divx and start the osund at the right time?
  2. Banned
    Jun 2001
    UK
    Try saving out the sound, if you intend using it later for VCD
    Audio > full processing mode
    Audio > compression > PCM (Default)
    Audio > conversion > 44.1Khz
    SAVE WAV
    This can now be used with TMPGEnc or Vdub depending on what your doing with it
    In Vdub you can also select Audio > interleaving > delay audio track by +/-
