How do I burn a VCD onto my harddrive then burn it onto a disc???
please help
thanks,
Phillip
perish1821@aol.com
How to Copy a VCD
Your questions can be answered by reading the guides found under How to author and burn a MPEG to a compliant VCD/XVCD in their entirety. Below are some quick and dirty instructions to copy an existing VCD.
Install VCDEasy 1.1.1 then go to:
VCDEasy 1.1.1 | Tools | (S)VCD Build/Rip | VCDxRip
Choose the location of the disc you want to rip by choosing:
o CD Reader | o CD Writer | o CD Image File
Make sure you have enough disc space in the drive location you choose, then click Rip.
You can also use VCDGearGUI to convert DAT files on VCD to MPEG-1 on your hard drive.
HUN-YA!
Akai Rounin
[EDIT: Since you asked how to get your VCD on your hard drive (presumably for editing or recompilation), I gave these methods. If you want to make a copy of your VCD on another disc, follow the posts below.] -
Or you can use CloneCD to make an image to your HD,
then burn the image to an CD-R with the same program
dilbert -
The easiest way is to load up your favourite CD burner proggy and click on the "Copy CD" function.
For those that like more control on what they are doing, CloneCD is great for copying CDs of all sorts.
Regards.Michael Tam
w: Morsels of Evidence
Can't make backup copy of new DVD Old Dogs
By mearmeans in forum DVD RippingReplies: 7Last Post: 15th Mar 2010, 20:02 -
Can't Make Copy Of A New DVD
By adrian2055 in forum DVD RippingReplies: 3Last Post: 6th Feb 2008, 14:39 -
Troubles Make Back or copy
By thebirdf in forum DVD RippingReplies: 1Last Post: 23rd Jan 2008, 01:53 -
How do I make a copy of a backup copy
By vaughndk in forum Newbie / General discussionsReplies: 8Last Post: 27th Dec 2007, 08:13 -
sonydvdarchitect4: cannot make copy from dvd which was made by architect
By mark70725 in forum Authoring (DVD)Replies: 7Last Post: 7th Jun 2007, 08:48
