When i use Virtual Dub so that i can save the audio as a separate file from the video i sometimes get a message saying that there will be a certain amount of SKEWAnd that i neew to decompress the whole WAV file and recompress at a certain bitrate ! Any body had this or knows some software that i can use for this ??
This problem hasn't happened to me, but you can use CoolEditPro to encode at various bitrates. CoolEditPro is not a free programme, but I'm sure hunting a little will find you a copy.
Dont worry about it. I get that everytime i convert a Star Trek TOS (divx avi) episode to vcd..When I rip the audio i get that message. I just save as uncompressed wav, 44hz 16bit stereo. Then I load the video up in tmpgenc, select my wav as audio source, load the default videocd(ntsc) template and it comes out perfect everytime and plays great on my apex ad-660..No sync problems at all..Hope this helps, good luck.
CamStudio AVI Files (WAV)
By foochuck in forum AudioReplies: 6Last Post: 7th Oct 2010, 19:50 -
DVD to AVI or WAV
By GarrettKooper in forum DVD RippingReplies: 2Last Post: 5th Aug 2010, 17:25 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 18:21 -
AVI to WAV in Virtualdub
By crumbworks in forum Video ConversionReplies: 20Last Post: 9th May 2008, 04:10
