I have a cvd samplefile (pal) for downloading.
This sample is ripped from parent trap (walt disney)
and encoded with tmpgenc.
With this quality i can get about 4 hours on one dvd (4.7gb).
I hope the quality is good enough for all quality freaks (like me) out there.
ftp://pmk.d2g.com:2121 This samplefile is about 191mb in size.
vcd4ever.
The server has now been online for 3 days, and so far only 2
completed downloads. I have now decided to shutdown the
server.
vcd4ever. -
well i got a copy. thanx.
what settings / template did you use then? would be useful to know...! -
theboywonder,
I'm not using any special template or settings in tmpgenc.
I only loaded the svcd template and unlocked it.
Then i applied these changes,
video: rate control=cbr , bitrate=2300kbit, encode mode=non-interlaced.
motion search: high quality (slow).
gop structure: I=1 P=4 B=2, sequence header=1/gop, max number of frames=15/gop, detect scene change=off
audio: audio bitrate=192kbit.
This is the settings used in the samplefile.
And thanks for downloading my file (it made me very happy).
vcd4ever. -
thanx!
no problem about downloading... thanx for putting it up! you have a fast server
time to look into that interlacing option..... never really considered that when encoding ....
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 15:58 -
Nearest Neighbor Video Resize?
By jenna12 in forum Video ConversionReplies: 2Last Post: 18th Mar 2010, 13:50 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Does HD-DVD player also rewind/FF to the nearest key frame?
By grasswhopper in forum Authoring (DVD)Replies: 1Last Post: 2nd Oct 2007, 00:13 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
