  1. I have a movie which the audio sound like it's mono, only one speaker is working, and it's sounds like someone was blasting the audio to the max when recording this, is there any way to make it work in all speakers (stereo) and a way to adjust the quality of the audio so it's bearable.
    Thanks.
    Email me at averyisiah@lycos.com
    or send me an IM.
  2. make a search on my posts for sound...
    "OO"
    P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
  3. Banned
    Jun 2001
    UK
    Thanks.
    or send me an IM.
    Save out the audio, then use www.goldwave.com and edit the WAV, you can make both channels the same and normalize etc
