I'm looking for a program that burns DVD-R's that will pretty much play on anything, that's all I want the program for, it's superior burning capabilities.
Thanks much
I've burned DVD folders to DVD using Prassi PrimoDVD, and had great results considering I used the cheap Princo blanks and they STILL worked on most machines.
I find the key to good projects is keeping the bandwidth of the content as low as possible. The higher the bandwidth, the more chance you may run into encoding errors.
However I have burned 200 DVDs with Prassi PrimoDVD and only have have less than 5 fail on me. Overall, the media plays just as important a role as the burning program when you look at playback compatability.
Regards,
Savant
What software burns avi to dvd without having to convert??
By bradztheman in forum Video ConversionReplies: 3Last Post: 20th Jan 2012, 19:41 -
dvd burning/convert program which burns both 4:3 and 16:9 for single movie
By vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 03:50 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 18th Aug 2010, 23:19 -
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 01:12 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 17:56
