Hi,
I hope anyone can help me with my problem. I just started to convert my homevideo to mpeg to put it on cd as (s)vcd. I used the tmpgenc encoder but till now the result is not that good. If i have a look at the original recordings i made with my digital camera it is a great quality but when they are converted to mpeg1 or 2 files i notice lots of little square blocks.
Does any one knows how to get an excellent quality ??
Already thanks a lot
Loe
well those little blocks are allmost impossible to completely remove, but there are some steps to make them a lot less noticable. First off, i would recommend that you use some noise reduction on it. Analog video can be very noisy, so its best to clean it up a little. This will give you a lot better quality. Also, you may want to see about increasing the bitrate a little. The more bitrate, the better the quality will be. Keep in mind tho, more bitrate means a larger file also..
Best camera to pick if you have a HDV camera already
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 29th May 2011, 15:58 -
DV camera maintenance? (also evaluate my camera)
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Jul 2010, 09:28 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57 -
Using a DV camera to import tapes from another DV camera to desktop
By bge20 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2008, 19:03 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 06:53
