I am trying to convert a mpeg with 320x240 resolution to a vcd. THe error message says that it is "NOT VALID RESOLUTION FOR NTSC ENCODED SEQUENCE". Is there a way to convert small resolution mpeg files? (PS this is not Divx)
Yes. Just select the appropriate VCD template to suit the framerate. Try a sample (using advanced>source range) first to see how it looks. I would start with Source aspect ratio 1:1(VGA) and Video arrange method = Full screen (keep aspect ratio). See how that turns out when viewed on the PC and then report back.
Originally Posted by jmussle
It's very common in TV episode captures and such. Unfortunately it ain't good for a damned thing as far as VCD/DVD. The difference exists because VGA pixels are square and NTSC/PAL pixels are slightly rectangular.
Use TMPGEnc to convert, using their VCD template, and using your picture arrange tab format as "center". The resulting video file MPEG will be slightly windowboxed when viewed on a PC, but most television sets will play it with a normal appearance. The centering is essential to preserve image quality; stretching to 352 at "full" will deteriorate your image. Only televisions with a lot of overscan will show the image edges.-MPB/AZ
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 17:30 -
Convert DVD to Xvid using original resolution
By iBeech in forum Video ConversionReplies: 5Last Post: 13th Jan 2009, 10:05 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
320x240 avi's to Half-D1 Resolution
By louv68 in forum Video ConversionReplies: 10Last Post: 15th Aug 2007, 08:12
