hello,
basically what i need to know is if i can play a movie i download off IRC in my DVD player??
my player can play almost anything so i thought maybe i can download movies and watch them...i checked out the FAQ and it says if i convert the .DAT file to an .MPEG i can watch it on my DVD player...now do i need a DVD burner and burn the mpeg on a DVD or can i burn the mpeg on a CD with a CD burner and watch it on my DVD player? (i dont have a DVD burner BTW)
so far i got VCDgear and can convert the BIN/CUE file to an .MPEG file, is that what i burn or can i burn the BIN and CUE file to a CD and play it?
sorry if these are stupid questions but thanks for your help!![]()
since noone helped yet i did a little more looking...
all i need to know is what format should the movie be in if i downloaded it off the internet and want to play it on my DVD player??
right now i have a BIN file which i mounted with DTools and theres a few folders, CDI, EXT, Mpegav, segement and VCD
EXT folder has LOT_X.VCD and PSD_X.VCD
VCD folder has entries.vcd, info.vcd, lot.vcd and psd.vcd
and the mpegav folder has a avseq1.DAT file
now do i need to convert that avseq1.DAT file to an mpeg and burn to a CD?
if so whats the best program to convert it to retain quality?
please answer a question if you can! any help is much apprieciated -
Since your dvd player can play almost anything, and since the file you've downloaded is in bin/cue format, I would guess that it's either a VCD or SVCD.
So, since your dvd player can play almost anything, burn the bin/cue with cdrwin on a cdr and stick it in your machine.
ta da. -
i got about the same problem.. burnt a bin on a cdr, and got all those same files and dirs. put it in my dvd player and i get a grey picture with lines going down the screen.... anyone please help me out. i think this is the second time this has happened.
i got a phillips magnavox dvd825
thanks.
Newbie that needs answer to a question: Transferring videos to a Mac?
By PlatS in forum Newbie / General discussionsReplies: 11Last Post: 10th Nov 2010, 23:28 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Dumb question, but should be easy to answer :). Re DVD Flick high quality
By cognus in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2010, 23:43 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34
