It seems as if there is a lot of conflicting information about creating VCD's and SVCD's with the WINTV-PVR 250. According to the instructions that came with the card, to burn a VCD I must capture, edit with the WINTV-PVR editor, and only then it is burnable. But I found that I could simply capture to VCD and burn with Nero with no problems (and Nero doesn't complain or have to re-encode), it plays just fine on my stand alone player (Apex AD-1200).
SVCD seems a bit more confusing. According to the instructions I basically do the same thing, but I found that Nero complains about the MPEG-2/SVCD not being compatible. And when I use DVD Moviefactory I can burn the captured file directly (using the SVCD SP capture mode), but the disc is all blocky/choppy when I play back on a stand alone player.
I also tried taking the 'SVCD SP' captured file and 'remuxing for SVCD' with the WinTV-PVR editor, but the output file is smaller/shorter and the burned disc has an audio/video sync problem.
Does anyone have any tips on how to do this (am I missing a step). Also, is the VCD method I'm using ok? Even though VCD's play fine in my player, I want to be sure I'm making a compliant VCD that is compatible with all players.
Thanks!
David Szlucha
Results 1 to 1 of 1
Happauage WinTv PVR 250, software concerns and advice.
By MidnightMike in forum Capturing and VCRReplies: 6Last Post: 25th Aug 2011, 11:37 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00
