hi, i've been having this problem for awhile and i posted a question on this forum to which no one replied. Anyway, the problem is, i have an svcd but to play it on my dvd player, i mulitplex it using tmpgn, doing the vcd header trick. The first cd worked perfectly however the second cd, while multiplexing stops half way and a messege appears "may cause buffer underrun when played" I dont know why it does this for the second cd and not the first. Can anyone give me advice on what i may be doing wrong?
Thanks and all help is appreciated
Then it sounds like the second is faulty, try re-encoding with TMPGEnc SVCD > VCD it may fix the errors
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 14:58 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
