    May 2002
    ENGLAND
    i can do the easy dvds,(the ones where the movie is less than 4.3gb) i can do the splitting onto two discs no probs, but i realy want it one one disk, so i realy need to shrink the movie. every time i use rmpeg2 it crashes, we have have three machines and it does it on all of them, does anybody have any idea what is causing this problem or have a better way to do this?
    Nov 2001
    Upstate NY
    I haven't actually done any of this as I don't have a DVD writer, but you may want to check out these guides
    http://www.doom9.org/mpg/ifoedit-cce.htm for Scenarist
    and http://www.doom9.org/mpg/maestro2.htm for DVD Maestro
    and this thread
    http://forum.doom9.org/showthread.php?s=138d97210035f7ac14d017f12125b181&threadid=17400
    over at Doom9. The forum thread covers other authoring software other than the two above if you work through the whole thing.
    Good luck.
  3. You may try this, it has worked for me. I rip main movie vob's, use DVD2AVI to create a .d2v project, use bitrate calc to find bitrate for desired file size, import into tmpg, use dvd template with 2-pass vbr where the avg. bitrate is the result from calc. Then encode. You should get an mpeg. file that you can send to spruceup or another authoring suite. Hope this helps.
    Apr 2002
    Florida
    corwin is right, use the CCE-IFOedit guide at doom9. CCE will run circles around rempeg and i have transcoded about 120+ movies and it's never crashed on me
