I've just been converting a .avi movie to a .mpg, and ran out of disk space. I have cleaned up lots now and the movie is at 85%. However, this took me over 8 hours to get there and i don't fancy restarting. The bar is still at 85%, and I can see the video stream (paused). The elapsed time has also stopped.
When I clisck start, it asks me if i want to overwrite the file. Please help me out here, I have TMPGEnc still runnung!!
You cannot directly, However, it is possible if you specify the frame number in source range, you can then continue from there.
Computers -
As Chris X said ...
- Make a note of the framenumber your have stopped on
- The partial mpeg should be saved on your HDD
- When you have the required space free on your HDD start encoding again but in Source Range specify the frmae number you wrote down as the start
- Once this portion has been encoded you can use the MPEG tools Cut and Join section to join the two mpegs
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Dvd-players with usb-resumable-playback support?
By sonam in forum DVD & Blu-ray PlayersReplies: 9Last Post: 12th Nov 2010, 12:54 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
