I bought an Apex dvd. It doesn't play my vcd's. divx burned by
easy cd creator. heard maybe they stopped playing
with the vcd's in the newer models. should i take it back and try
another product?
divx burned by easy cd creator???
What? that is not vcd....or do you mean that you convert the divx to vcd and burned with easy cd? -
i down loaded the file and burned it to a cd using ez cd creator as a data cd.
That is not a VCD.
You must convert to vcd and burn as vcd.
www.vcdhelp.com/convert.htm#vcd
www.vcdhelp.com/author.htm#vcd
www.vcdhelp.com/divxtovcd.htm (all in one guide) -
Message received from Apex yesterday:
Your Issue Was:
The AD-1100WB is currently on sale in the UK. Does it have the capability to play VCD and SVCD?
Apex Digital's Response Is:
no player manufactured after 4/15/02 will not play vcd\'s
Thank you for using our website! -
If VCD won't work try SVCD....or have they removed it too?
I don't know - I decided not to buy one!
However, since making a DVD player play VCDs is trivial, it must be part of a wider policy to prevent playback of VCD for some reason - perhaps pressure from the movie industry? And if they removed VCD capability I suspect they would also have removed SVCD capability.
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 21:29 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 14:36 -
SmallDVD doesn't work
By dnix71 in forum MacReplies: 10Last Post: 29th Aug 2007, 00:47
