Ok, so I read all htese guides and FAQ's, and none tell me what to do after I've ripped a DVD thats 5.6 GB that I want to burn on a DVD-r with a capacity of 4.7? I mean, I understand that I should strip some of the 1gb audio files for spanish, french, etc. but when I do that via IFOEDIT or DVD Decrypter I still have the same number of files and the same sizes. How can I cut out some stuff. Please excuse my newbieness.
If you strip via IFOEDIT, then the resulting files should definately be smaller than the originals. Do you see it going thru the process of creating the new VOB's? You should see it process all of them for the current working set. It will not modify the original VOB's, so make sure you are checking in the output directory that you specified in IFOEDIT.
im a total newbie as well, at first i thought you had to use ifoedit to strip and save , but i didnt realise you had to create a totally new directory and have that as the destination for ifoedit to strip to, i thought you had to overwrite the existing. me fik
Stripping DRM from WMV files odd issue
By pcbguy76 in forum Video ConversionReplies: 14Last Post: 28th Mar 2012, 13:46 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Problems when playing DVD VOB files
By rbrown871 in forum Software PlayingReplies: 2Last Post: 25th Nov 2008, 20:10 -
Stripping DVD extras, while retaining menu
By Hurre in forum DVD RippingReplies: 3Last Post: 19th Feb 2008, 10:14 -
dvd iso/files burning problems
By CommanderZero in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 01:25
