I have a flash movie that i have captured and converted it to avi but the problem is that the program i am using to capture dosent capture the sound so i need a to find a program that will record the sound for me.I will proboly try virtual dub to add the sound on the vcd.
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P
dload Flash or Swish and get the sound....
www.macromedia.com
http://www.swishzone.com/index.html
also, www.totalrecorder.com
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
problems adding 5.1 sound using virtualdub mod??
By pete7769 in forum AudioReplies: 4Last Post: 24th Jul 2009, 16:45 -
Adding Sound to WMV
By FredAt in forum ProgrammingReplies: 0Last Post: 15th Apr 2009, 00:39 -
Adding sound to video?
By Koron in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 08:58 -
Recording music,editing,adding sound effects ect...
By f-zer0 in forum Off topicReplies: 6Last Post: 20th May 2008, 08:44
