My dvd player only accepts vcds. So I burned Resident Evil and a few other movies. When I play the movie on my tv, I get a bunch of blotches and wierd sounds come like out of sync noises. The video on the screen just gets really ugly. I used tmpgenc to burn it to a cdrw by imitation.
My settings are for resident evil when i converted it from svcd to vcd:
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
If anyone could help I would appreciate it.
Results 1 to 10 of 10
Assuming that your MPEG isn't simply really bad quality (did it look like that after you encoded?) you probably simply have a media compatibility issue.
Many DVD players are not designed to read CD-R/W media and do so badly/not at all.
You can try to experiment with different brands of media to find one that works for your machine. CD-RW often does work better than CD-R in these machines.
Regards.Michael Tam
w: Morsels of Evidence -
it looks fine on my computer, really good quality and i use cdrw which is compatible with my dvd player
The symptoms you are describing suggests that your CD-RW is not particularly compatible with your DVD player. Those effects are caused by the MPEG being incorrectly read or unread.
Regards.Michael Tam
Have you checked the DVD Players link here at vcdhelp and checked out the reports on your DVD player to see what media brand works for other people ?
have you tried other media brands that are known to work with your DVD player ?
Originally Posted by fs8456
As for the answer to your question, I've already given you the solution in most first post on this thread:
You can try to experiment with different brands of media to find one that works for your machine. CD-RW often does work better than CD-R in these machines.Michael Tam
Problems playing 1080p files on VLC player
By Tafflad in forum Newbie / General discussionsReplies: 20Last Post: 20th Oct 2011, 16:29 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
problems playing dvd movies
By bexiga in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 19:37 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 13:23 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16
