When I burn VCD's in Nero, I can play them back with PowerDVD, but when I burn SVCD's, it won't play it. The MPEG files can be accessed directly on the disc and Media Player will play them, but not PowerDVD.
The directory structure is the standard SVCD format.
Hmm, I'm running ver 2.55...
Dai
this happens to me aswell.. and i'm using 4.0 (xp).. i'm not sure why it happens, but when it does i just have it play the mpeg file from the disc through powerdvd and it works just fine..
I don't think PowerDVD XP actually supports SVCD format playback (though it can play MPEG-2 files fine). Try WinDVD.
Regards.Michael Tam
w: Morsels of Evidence -
Well, I just tried to play a VCD I burned in Nero and I get the same message, so I don't know what to do. I mean, the point of using PowerDVD is try to play it as a dvd so I don't have to get up and go to the room the standalone is in.
Dai -
powerdvd xp works fine with svcd's no bother just the older version 255 used to give loadsa crap!
i use power dvd xp v4.0 with all my svcd's...works fine for me....think it has alot to do with your dvd-rom drive...???
Thank you,
Madmanincognito
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 19:32 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
BR structured image file is found as "unsupported"
By besthost in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Jun 2009, 02:06 -
"Unsupported audio rate in file" Message in Premiere Pro CS3
By JustinBaker in forum AudioReplies: 2Last Post: 23rd Mar 2008, 23:27 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
