Results 1 to 9 of 9
    Jul 2001
    Maryland
    capture dv directly to MPEG 1
    or
    alter the resoltuion of the captured DV to 352x240 so I can fit more dv on my disk, and making it easier to encode tv episodes
  2. Try Mediocampeg RT.
    In this industry, Sadly, The future was yesterday.
    Jul 2001
    Maryland
    where might i locate that program and will it do number 1, number 2 or both?
    Jul 2001
    Maryland
    neyone?
  5. Member djmattyb's Avatar
    Dec 2001
    Seattle
    I can't believe that pacoreguenga just posted and split! I found the website for the company that makes what you're looking for:
    http://www.mediostream.com/products/index.html
    Check it out. Looks like it captures straight to VCD or DVD for you.
    dj matty b
    Jul 2001
    Maryland
    I can't seem to find NeoDVD, and I have no money.
    Any other progs?
  7. Greg12:
    Search on Edonkey, WinMX or something. But if you use it a lot and like it, try to buy it.
    Jul 2001
    Maryland
    I might, I wanna try it first though.
  9. For sure try it first. I never buy before I try either. And to be honest I don't buy if it's too expensive for what it does (like a lot of Adobe products). At $50, if Neodvdplus does what it says, they're not being greedy at all.
