I have a problem sending audio through the digital port on an Audigy. I'm trying to connect it to a my MidiLand system, but I get no sound. I use a wire that has one of those headphone type of plug at one end and at the other end it's a regular RCA plug(the MidiLand has optical and coaxial inputs).
When I choose "Digital Output Only" under the advanced volume control, I still get no sound. Does anyone know why? I know that the cable is working cuz I tested it by plugging it into my disc man to a tv(I was able to hear sound). Thanks.
i have the audigy.
I have never tried this cuz midi equipment is expensive but this is what i do know-
You have 2 MIDI inputs.
One of the midi inputs is ALSO the Line 2 input as well.
Make sure you have both of those unmuted and volume up.
Now the other midi in looks similar to an s-video connection. Your audigy should have came with 2 adapter wires for this port as it has the same port as the MIDI out. Try those out too and also, make sure they are unmuted and vol up
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Dec 2010, 00:25 -
turn an audio in port into an audio out port?
By cduval04 in forum AudioReplies: 12Last Post: 19th Dec 2009, 09:03 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 22:45 -
How to connect VGA port on laptop to Svideo port on tv
By hulk420 in forum ComputerReplies: 4Last Post: 5th Jun 2008, 16:07 -
Audigy Vista Alchemy fiasco...
By ofbarea in forum ComputerReplies: 1Last Post: 3rd Jul 2007, 09:51
